996 gearknob
Yes it should, Ian.
I have one on my 993, and I am sure the 964 uses the same flat shift lever.
Obviously, the boot on the 996/Boxster is much different. So you must source a new or used 964/993 as a donor, or perform surgery on your original one.
If you take a look at any of the Porsche Tequipment carbon, aluminum, or wood shifters, you will see how the boot is attached to the ****. It is just folded under and secured with two tie-wraps.
The basic 996/ Boxster ***** are leather and silver plastic with a rubber sleeve that friction fits over the shift lever. The aluminum, wood and carbon ***** also have a set-screw.
here is a picture of my standard 996 ****/993 boot:
The one snag with a 964 install would be the shift pattern. The 996 bis a 6 speed, and the Boxster's reverse gear is to the right and below 5th IIRC.
A possible solution would be to use the 996 shifter that has the all silver platic insert. fill in the grooved pattern for 6th with epoxy etc. , then sand and repaint the complete plastic portion of the shifter.
this is the style that i am talking of:
Of course, you know your shift pattern by now
so you could just drive it with any sort of numbers on the **** !
I have had several different shift ***** on my car, but the one I pictured is my favorite for feel. and the looks aren't bad either.
later,
max
![](http://forums.rennlist.com/upload/996custshft3.jpg)
![](http://forums.rennlist.com/upload/996slvr6a.jpg)
later,
max
This is a great shift ****: http://www.carnewal-europe.com/cpx_p96165.htm
I am not sure how the shift pattern insert is kept in place...but you may be able to remove it and have an insert with the correct 964 pattern fitted.
This **** has some heft to it compared to the stand 996/Boxster ****.
It's price is comparatively heavy too !!
max
max
Registered User
thats the one i was thinking of !!
to go with this ......................
http://www.carnewal-europe.com/main.htm
Registered User
did i mess up the link again ???
i want your steering wheel , and the carnewal gearnob that max linked to , and the leather/alu handbrake with porsche engraved in !!!
that lot will be about 700 quid , but the alloy bits will match my new dials , and my new cd player !!!!
Here is alink to some that look cool. I actually like the carbon fibre 986 one. My red one with the carbon insert should be here the first of next week. Not sure if I am putting it in or not though.
http://www.stuttgartperformance.com/...f=intprod&cat=
