Tool Set Poll
Originally posted by ian c - u.k
the only thing i wouldn't scrape on are ................
torque wrench ,
jack ,
stands ,
pry-bars ,
and anything thats likely to hurt you if it fails !!!
torque wrench ,
jack ,
stands ,
pry-bars ,
Fastener damage from cheap tools is easy to spot. It makes me suspicious about use of cheap parts and other repair short-cuts.
Visit the Snap-On web site for a detailed explanation of why their tools won't round or damage fasteners. Anyone that has a hobby-grade tool and a professional tool, use them on a double-nut on a high-strength fastener that you are strong enough to break. A cheap tool will round the hex nut. Use two professional tools back-to-back, and you will break the bolt at more than double the torque developed by the hobby grade tool.
You may do fine for a long time with hobby grade tools, but you will come to grief when you face a particularly stubborn fastener. You need the extra margin provided by good wrenches to stay out of trouble. Damage only one fastener to the point where you can't remove it, and you cost yourself far more than you save on inferior tools.
Good question. I am thinking about stacking and nailing lumber sections to step up gently enough to avoid scraping the chin. The problem with ramps is finding space to put them when not needed.
I have "rhino ramps" which actually worked with an earlier car I had with only 3.5" of clearance and a lip spoiler. They only give about 7" of lift so I have an additional 'ramp' to them of 2x10s, staggered so it adds another 3" -- works great.
I believe they cost me about $35 at a parts store near here. They're plastic and light weight so pretty easy to store.
Hope this helps. Joe W
