964 Forum 1989-1994
Engine knock
Old Aug 9, 2020 | 06:12 PM
Black964cab's Avatar
Black964cab
Default Engine knock
Hey All,
Im hoping someone could help me in identifying a new noise. Recently I have started to notice a knocking when turning off the car when warm. It doesn't happen at any other time except shut off when the car has warmed up. Other than the new knocking sound when turning off, the car operates perfectly. The only recent changes are a secondary muffler bypass and and oil change (15w50 mobil 1).
Any help in identifying the new mystery noise before taking it in to the shop is greatly appreciated.
Movie attached
Thanks again
File Type: mov
Old Aug 9, 2020 | 06:27 PM
heliolps2's Avatar
heliolps2
Originally Posted by Black964cab
Hey All,
Movie attached
Thanks again
I don't think it's anything to be concerned about, maybe bad gas.
Helio
Old Aug 9, 2020 | 07:20 PM
Black964cab
Helio
Thanks Helio. I figured (was hoping) it might be something like that. I've only filled it once since buying the car. Guess I will try a different gas station next time.
Old Aug 9, 2020 | 11:20 PM
964Andrew's Avatar
964Andrew
Valve adjustment and heavier oil fixed it on mine. Regardless there is nothing to be worried about, just a normal engine shutdown sound dependent on many factors.
Thanks!
Andrew
Old Aug 10, 2020 | 11:01 AM
JasonAndreas's Avatar
JasonAndreas
Technical Guru
That sound from the chain guides and the timing chain, occurs when the hydraulic chain tensioner loses oil pressure.
Old Aug 11, 2020 | 12:51 PM
Black964cab
Thanks all for the replies. Much appreciated. Seems like its not much to worry about.
