Veloce GT1 wheels
Those offsets will work on our cars; the standard is 52-55mm. There is not a lot of leeway, however, under the fenders so 225f / 255r tires would be the max sizes I'd use with these wheels ... unless you're ready to play with spacers, camber, oil lines and rolling your fenders.
Greg, From pics of your car, it looks as if you might be running spacers front and rear or utilizing offsets which are smaller than the standard spec. Your wheels appear to be sticking out pass the fender lips which is atypical for a stock wheel. You may want to give everything a once over to confirm your current offsets and then proceed from there. It could just be the camber.
![](http://forums.rennlist.com/upload/frontend2.jpg)
Originally posted by C4TT
I did some research, and they are in fact TUV approved.
But I still wonder not being a wheel fitment expert, if they will fit a narrow body 964..
Does anyone know?
Does anyone know?
"They will fit your car directly WITHOUT any spacers or wheel arch mods. "
Thanks for this info! (nice pic)
As of now, I am running 245s and 215, with no real slippage issues. So going to 225 and 255 will be fine.
And I would prefer not to play the role/spacer/oil line game...
Thanks again!
Greg
