Mysterious Rolling Noise
This is going to be tough to describe... I am getting pretty significant mechanical noise when rolling and I started a process of elimination. It is probably not the engine since the noise is not rpm specific and the nose goes away when car is stationary with engine running. I just changed oil, atf, final drive, and adjusted valves. It does not seem to be tires since the noise does not change with different road surfaces. It is speed dependent but not massively. The wheel bearings are new (less than 400 miles), the rear axles are newish with less than 3,000 miles on them. I cleaned the brake calipers and none of the pads are binding. The brake fluid needs changing as it is 2 years old. So what else transmits rolling noise? Could this be an indication that the upper shock mounts are going? The rubber is the original I believe. What else am I missing?
Originally Posted by 964Andrew
Rolling noise on mine turned out to be bent wheel. There was no vibration BTW, just noise. After straightening the wheel the noise went away.
Thanks!
Andrew
Thanks!
Andrew
Oh, and the engine and transmission mounts are also new. Less than 100 miles on them.
I presume you had your wheels on and off a few times... Which makes it less likely what I'm about to say adds any value.
But have you checked that the lug nuts are tight all around?
Rocket Rob (07-06-2020)
Originally Posted by Dick964
After replacing the wheel bearings, did you tighten the nut to the torque specifications with a torque wrench ?? (I don't mean the 5 wheelnuts on each wheel here...)
BR,
Dick
BR,
Dick
Ok, ask your mechanic...
Either the bearings are to loose or too tight if you did tighten the nut 'on feeling' instead of using a torque wrench (460 Nm....without grease on the bolt or nut !!)
The bearing will start to make a humming noise not long after you install them without setting them to the right torque.
And the 'nice thing' of it all is that you (often) will not feel any play in the bearings while they make this humming noise. Over time the noise will become louder.
Greetings,
Dick964
Greetings,
Dick964
Greetings,
Dick964
Greetings,
Dick964
Replacing the rear tires cured the noise 100%
... Gregg
Wouldn't the tires create different noise based on road surface? Concrete usually sounds different from smooth asphalt for example.
Has anyone any idea how long the upper shock mounts last? I am talking about (10) in the relevant PET, i.e. the rubber piece that isolated the shock assembly from the chassis.
Thanks.
Thanks.
... Gregg
I think I found the issue. The upper shock mounts were toast. Road noise getting transmitted into the tub.
![Name: photo187.jpg
Size: 1.77 MB](https://rennlist.com/forums/attachments/964-forum/1315493d1595099851-mysterious-rolling-noise-photo187.jpg)
Old on the left, new on the right
![Name: photo795.jpg
Size: 1.70 MB](https://rennlist.com/forums/attachments/964-forum/1315494d1595099851-mysterious-rolling-noise-photo795.jpg)
The issue is a completely compressed mount.
