964 Won't start Help
My car as running perfectly fine two weeks ago. I took it to get Smog, passed. To celebrate, I drove it around and had a fun after the test. Parked it in my garage. Two days later, I was going to the bank, but it didn't make it. I checked up and stalled. I turned around after a quarter mile and came home, barely made it back.
After reading through some threads here, I have replaced the DME Relay, and Fuel Filter. I checked the sparks by pulling the plug wire and connect to a new plug. There was sparks! What’s next? I’m posting a video of how it wants to run, but something is not working right.
vsouvann (05-31-2020)
Just found out what was wrong with my car. It's gotten a broken Distributor Belt. I'm going to take it out and see if I should rebuild it myself or send it off to a pro to fix it.
Car should start and run on one distributor so you may have another problem lurking somewhere. Broken belt needs to be addressed regardless, I don't have any first hand knowledge of this procedure but there should be plenty of good resources here.
vsouvann (06-04-2020)
