964 Forum 1989-1994
wheels Maxilite cup1
Old Mar 31, 2020 | 10:44 AM
Carguy123's Avatar
Carguy123
Default wheels Maxilite cup1
Does anyone know if you can run 15mm spacers on the Maxilite cup1 wheels 17X9 47mm offset on a narrow body 964? If not what is the widest spacer you can use at European ride height?
Thanks Porsche people!!
Old Mar 31, 2020 | 11:03 AM
weekndr.porsche's Avatar
weekndr.porsche
That would be an effective offset of +32mm.
I run the 17x9 +55mm wheel on the rear, with a 20mm spacer - so effective +35mm.
Yours would be poking out 3mm more than mine.
Which I don't think would work - I tried.
(depending on alignment and camber)
Make sure you have extended lug studs.
Old Mar 31, 2020 | 02:57 PM
Tarek307's Avatar
Tarek307
You will either need the spacers with studs that bolt onto your original studs, or you will need to change out your studs to extended studs which is kind of a pain.
Old Mar 31, 2020 | 05:25 PM
Carguy123's Avatar
Carguy123
I bought the 15mm H&R spacers with studs and thought I would like the wheels that came on the car but I still don't so I will stick to my original plan of getting Maxilite cup1s but was wondering if I could use the spacers I just bought. If not i guess i can sell the wheels and the spacers a recoup some of my money
Old Mar 31, 2020 | 07:21 PM
Tarek307's Avatar
Tarek307
the short direct answer is if you bought the normal spacers NO you cannot just add them- you have to get extended studs-
Old Mar 31, 2020 | 07:39 PM
Carguy123's Avatar
Carguy123
I bought the H&R 15mm spacers with built in studs. will the rims fit under the car?
Old Mar 31, 2020 | 10:45 PM
Tarek307's Avatar
Tarek307
Yes they will, no problem. and they will look great! As long as you got the proper offset maxilite i think 47 52 something like that you are good to go, iv'e used those wheels on many 964 and some with spacers like yours
Old Mar 31, 2020 | 11:00 PM
Carguy123's Avatar
Carguy123
I want the same look as on your car. Love it! Will I have to roll the fenders?
Old Apr 1, 2020 | 10:16 PM
Tarek307's Avatar
Tarek307
no you don't need to roll the fenders, nothing!!! The look of the car you see on my profile pic was 7mm spacers all around with maxilite and didn't used extended lugs (which is not recommended because i lost 1 or 2 turns in tightening lugs but i didn't care)
Old Apr 1, 2020 | 10:25 PM
Carguy123's Avatar
Carguy123
Man yours look like they are at the end. I hope 15mm is not to much. Thanks
Old Apr 4, 2020 | 06:18 PM
Carguy123's Avatar
Carguy123
What size tires are you using. Thanks for your time!
Old Apr 4, 2020 | 09:14 PM
Tarek307's Avatar
Tarek307
i already told you man, the pic of the ones on the car in the profile pic 7mm all around spacers, and same maxilite you have - but this is not recommended because you lose a turn on tighening the lug bolts if you don't use extended lugs
