Disable Passenger Airbag?
#31
I don't want to reopen the debate about whether or not to do this. I have done it, and I respect everyone else's personal decision.
My question is this: does installing 928.612.220.00 get the job done by itself, or do I have to disconnect the white plug with the two wires as well?
By the way, 928.612.220.00 is a $35 part (purchased from Autometrics) not a $100 part.
Thanks!
Thanks!
#32
Super Duper Moderator
$35.12 at www.pelicanparts.com too (a Rennlist sponsor).
Sorry, can't answer your question (but have one of these on order myself).
Marc
Marc
#33
Hi all,
I searched all over but can't find the actual value of the resistor. Is it a 2 or 5 ohm? I'm trying to disable the passenger airbag on a 91 cab. It is impossible to fit any seat in the back and be able to open and close the top. Thanks.
Patrick
Patrick
#34
Viper Bob in a post says 2.8 ohm 1/4 watt for the passenger side.
https://rennlist.com/forums/964-forum/122479-okay-you-asked-for-it-momo-wheel-installation-made-easy.html
#35
Lead Rennlist
Technical Advisor
Lifetime Member
Lead Rennlist
Technical Advisor
Lifetime Member
Patrick,
The resistance value depends upon the type of airbag. They are NOT all the same.
The easiest way (using a low ohm meter) is to measure the actual resistance of the airbag and substitute this value with a resistor. However many people still have the warning lights come on and require a reset. If you read the entire thread you posted you will see this mentioned more than once. One guy even pulled the airbag warning lamp. I have seenthis many times when 964s and 993s have been sold on and thenew owner cops the repair bill.
I have been researching this issue myself for other reasons and I recommend you take a look at the airbag disable switches that are being offered in the USA. This way you can arm and disable the airbag as required. Just do a Google search.
Ciao,
Adrian.
Ciao,
Adrian.
#36
I should have ohmed it out. I did not and I have the lights coming on. The seat belt and the airbag lamps. I will check the correct value and then do a reset. The airbag I have has two-two conductor connectors. I placed a resistor on each.
At least I know the airbag is disabled and the car seat is safe in that regard. I tried a few booster seats in the back. I can see a coupe fitting but with the cab the hinges and the rear window movement is obstructed.
Thanks again.
Thanks again.
#39
Guys I hate to dig up this old post but I am carrying out this process and would like some advice if possible. How do I mount the resistor in the connector or connectors? If there is only one connector do I place one end of the resitor in the plug and the other?? If there are two connectors do I loop one side of the resistor over to the other plug??? Apologies but electrical repairs are new to me.
#40
I am curious if it is possible to run a no airbag steering wheel with a functional passenger airbag?
I assume that if possible you would always trigger the aurbag light right?
Thanks in advance!
Thanks in advance!
