Racing Dynamic wheels?
I havent been able to find some AT Italia rims...and I found this model of Racing Dynamics are very close to the same look.
Anyone know where to source them in size 16 or 17 "...do they fit the 964.
RGQ Wheel
RGS Wheel
Adrian....I will take donations whenever you get tired of looking at your Ruf's!! Those are the all time best looking rims ever.
RGQ Wheel
RGS Wheel
Technical Specialist
Lifetime Member
Lifetime Member
On fit, you want them to be, optimally, 52mm offset. 50mm-55mm may fit fine. Anything larger than that will require a spacer to move the wheel away from the body. So, for example, if you find that they come in 65mm offset, you'd want a 13mm spacer, give or take a mm (65mm-13mm=52mm). Offsets less than 50mm may not work in front. If looking at at wider 9.5" or 10" rim in back, 47mm offset usually works well. Note that lower offsets can't be 'fixed' with a spacer. Assuming your brakes are stock and not big reds, as big reds generally require 17" rims.
Unless he snuck that one in there!!
