Hello all I pulled what looks to be the original flywheel off my October 5, 1990 built C4. The flywheel along with the clutch are stamped with a September 1990 build date. Based on what I read here this suggests my car has the Fruendeberg dual mass flywheel. However I also see that the ring gear is bolted on and I read suggestions that this indicates that LUK. I could not find anything definitive with regard to the part number. Can anyone assist?
Thanks Rob I hadn't seen that thread. I believe PET and the date code suggest my flywheel is the original. I don't have a way of confirming that the original is in fact a Freudenberg - does anyone have a known Freudenberg photographed or further confirmation that the part number was manufacturer specific?
