964 wiper blade upgrade?
Though I rarely drive my 964 out in the rain, the archaic Bosch wiper style bothers me. I purchased Trico single beam wipers (13", with "confirmed fitment"), but they do not appear to fit the curvature of the driver's side well at all (worse than the OEM Bosch units, surprisingly--more liftoff at the sides and only the middle of the wiper contacts the windshield). I have not been able to find any other manufacturer that even claims to fit. JIm
I am wondering, has anybody been able to upgrade their wipers? Is the only option to perform a 993 wiper upgrade? I am guessing that is a pricey proposition, so cheaper suggestions would be preferred.
Thanks!
Jim
Thanks!
Jim
In 92 They went from the single spring version of the wiper arm to a double spring version. Not saying it is a huge improvement but did help. If you have the two spring version I guess you are SOL if not might be worth a try. I only drive in the rain when I get caught and all my cars seem OK with the double spring and fresh blades.
Thanks!
Jim
Thanks!
Jim
IHI KING!
I've had good luck with Silblade wiper blades. They are made with silicone instead of rubber. I've gotten 10+ years out of each set. Both of my cars have the single spring arms. Upgrading the arms is not a high priority for my use.
Heritages (08-29-2023)
All the time, and mine is a C2 Targa!
To be sure, I have a little internal debate every time, but it's just too much fun not to drive it. Since I finished monkeying with the top adjustments she doesn't even leak. That said; I do have all-seasons, HID headlights, and the bottom trays all on... plus she lives in the garage at home and at work.
I draw the line at mud and snow though - we use too much salt around here so I use the landcruiser for that business.
I use Silblade on my DD's lifetime warranty and they leave a rain ex type coating allowing water to beed off easily. The down side is the arms don't sit as flush. I DD a 911 for many years and countless miles. Just can't do it anymore. Happily take the 4 doors out for most crappy drives.
One thing that really helps is a properly cleaned and smooth glass surface. First wash, then use Groit's Glass Cleaning Clay and then put on Groit's Glass Sealant.
Thanks for all the responses!
yes, glass has been polished and cleaned well, no issue there.
The wipers are rarely used—-I do mainly try to avoid rain but occasionally you have to give it a swipe even with the RainX in the occasional drizzle you get caught in!
I will consider the Silblade or maybe just try putting on my Trico to see if they conform as suggested.
Double spring arm conversion—-might not be worth the cost for my rare usage, and I think I am mainly bothered by the nonconforming wiper blade at the outside edge.
thanks!
thanks!
