Manifold gasket help
1991 964 C2
Installing new manifold gaskets. Stuck on a couple of things and thought others must have the answer/solution:
1. Which side of the gasket goes to the engine - the flat side or the rounded side? I'm guessing flat to the engine and rounded to the manifold.
2. Anyone have a trick for holding the gaskets in place while fitting the manifold? Gravity wins every time.
Thanks in advance. Nick
I use a little antiseize to stick the gaskets to the engine. I put the new gaskets on the same as the old ones were installed. I think there is a post on here that shows the proper orientation but I cant seem to find it.
