Looking forward to a report on the Elephant Tie Rods. They've been on my list for a while but haven't gotten around to it yet.
You will love them! Steering feels much more direct, and noticeable decrease in bump steer in tight corners. The front end feels planted and playful.
Elephant tie rods + Rennline HD ball joints, Rennline 3-point strut bar, and steering rack brace and bushings. 235 front tires.
I don't use a lot of negative camber when i set these up for street driving. I look to balance the handling out a bit. On the street, where hopefully you are never driving at the limit, balance is more important, as is predictablility. Speed is irrelevant. On the street it's about feel.
In my opinion, i don't know your ride height specs, but raise the car to RS plus 10mm if it's lower than that, and i wouldn't go so far negative in camber. A little toe in front and rear, max the camber, and if you have adjustable front and rear swaybars, adjust the rear to max stiff and the front to max soft. (For a start). Then tweak as needed until you get it dialed in.
Anyway- remember - race cars feel like **** and don't drive well. They just go fast around a specific set of corners under specific conditions, with specific components, set in a specific way for that day. Street cars are different. We aren't racing, and we want to feel like we are.
Feelings aren't facts.
My settings are:
Front
Rennline camber plates up front (monoball)
New-ish control arms
Refurbished steering rack
Rear
V1's have monoball topmounts
ERP adjustable spring plates
Cup 1 Reps (17in), Michelin PS2
Carrera RS spec heights + 10mm
Front V=135mm
Rear H=228mm
F -2deg camber, slight toe out, max castor
R -1.5 deg camber, neutral toe
The car can be a bit 'busy' on bumpy roads, so planning to address that at some point (bump-steer probably). Generally damping/compliance are pretty good, though the roads in my town are good. Also thinking of slightly more camber and toe-in at the rear when my larger wheels go on. I'm not interested in firmer sway bars because I'm paranoid of getting bitten by lift-off over-steer. Will take the (minimal) body-roll instead...
One thing to bear in mind for later, I have KWv1s and the ride height dropped nearly 4cms after they were initially set up (at some point over about 4k miles, which was the next time I got the ride height checked)
Ive had a few years of messing around with various suspension and alignment set ups and have always found that my car feels a lot better on the road or track with more camber on the rear than the front and I can get away with just under 2° front and 2.5° rear and wear even on the rear and finish fronts off with 1mm difference from inside to outside with a mix of track days and fast road, no commuting, toe out is a no go for my skill, far too darty and feels like I've wound all the caster off, I'd imagine it's good for auto cross though! Caster wants to be maxed out for whatever your doing with the car. A tiny bit of toe on on the rear helps a lot for me, keeps the rear end in check, especially under hard braking. I'm hoping a new diff will help further! As for ride height, at 10mm under rs height with rs progressive springs I had horrendous bump steer on the road, fine on a smooth track though. I then went to linear springs and this helped loads with the bump steer as it limited the suspension travel but it became harsh on the street. I then went to motons and 620 855 springs, rd uprights and tie bars etc and set it up 25mm below rs and the car handled like it was on rails on the track, was better on the road but not when going less than 35mph. As the family keeps growing I see less and less track time so I've revalved the rear shocks, fitted longer 500 and 680 springs and gone back up to rs height and the car now feels like I'd imagine a modern gt3 to feel. Firm but supple on the road and I'm hoping I'm still able to get it stiff enough for the track.
