964 Forum 1989-1994
Help! Cleaning ISV & Airflow meter
Old 02-22-2004, 04:18 PM
robmug
robmug's Avatar
Default Help! Cleaning ISV & Airflow meter
Hi all
In an attempt to cure my stalling when cold, I've decided to spend some time this evening cleaning the ISV (Idle Speed control Valve) and the air flow sensor flap.
1st question. Which is the ISV.
2nd question - how easy is it ti remove the airflow meter assembly & clean? Any pitfalls I should be aware of?
Old 02-22-2004, 04:21 PM
ian c - u.k
Registered User
ian c - u.k's Avatar
rob ,
post a picture and wiull point them out to you
have you got a can of carb cleaner ???
Old 02-22-2004, 04:22 PM
robmug
robmug's Avatar
Ian - pic posted. No carb cleaner, but I do have a can of solvent...
Old 02-22-2004, 04:25 PM
John Boggiano
Lifetime Member
John Boggiano's Avatar
ISV...
Old 02-22-2004, 04:27 PM
ian c - u.k
Registered User
rob
john beat me to it !!
carb cleaner is better , plus it has a nice smell
failing that i would use isopropyl alchohol
what solvent you got ??
Old 02-22-2004, 04:28 PM
ian c - u.k
Registered User
john ,
that is one clean engine !!!
Old 02-22-2004, 04:29 PM
adewatson
adewatson's Avatar
Rob,
I believe it's fairly easy to clean aparently according to my mechanic it picks up carbon deposits.
When she went in for service earlier this week I called in to check progress and my car was sat idling very erratically. This was at 3pm and I picked the car up at 4.30pm with the problem solved and the ISV cleaned.
You'll be pleased to know it has completely cured my cold stalling issues.
Adrian
John Boggiano
Lifetime Member
I know, but it's Rob's!
Old 02-22-2004, 04:30 PM
robmug
robmug's Avatar
Thanks John...how do I clean it...does it come apart easily?
Old 02-22-2004, 04:31 PM
John Boggiano
Lifetime Member
Rob, you want to glue up that soundproofing. I did a great job with 'No More Nails' from B&Q!
Old 02-22-2004, 04:33 PM
robmug
robmug's Avatar
Ian
I've got a can of Amberklene FE10 (A powerful, fast evaoporating degreasing solvent that leaves no residue). No idea what's in it!
Old 02-22-2004, 04:34 PM
ian c - u.k
Registered User
clean it by spraying loads of carb cleaner in it , then wipe , then do it again , then wipe , then re-fit !!!
easy
sometimes you have to let them soaj in carb cleaner overnight , depends on how contaminated it is
Old 02-22-2004, 04:36 PM
ian c - u.k
Registered User
rob
read the tin , see if it says
ipa , or isopropanol , or isopropyl achohol .
i aint no chemist , so i aint gonna recommend you use it . sorry .
can it not wait till tommorrow when you spent a couple of quid on an earosol of carbueretta cleaner ??
robmug
robmug's Avatar
Sounds like I'd better get some carb cleaner & do the job tomorrow then!
Old 02-22-2004, 04:37 PM
ian c - u.k
Registered User
maybe someone else will reply with good news !!
Quick Reply: Help! Cleaning ISV & Airflow meter
