Hi all, I've read every thread on Rennlist and elsewhere for the removal of the lh HVAC fan and looked at a gazillion pics of it. I've gotten to the point where I've inserted a screwdriver/hacksaw blade into the slots behind the fan. I have tried with various screwdrivers/hacksaw blades, twisting, turning, levering to get the motor out all to no avail (the two torx screws have been removed). I've attached a couple of pics (front/back of fan) where I think the screwdriver goes in (1st pic, red arrow) and where it is supposed to "come out" (2nd pic, wide red arrow) and press down on the tab (2nd pic, red rectangle). I've also tried lightly hammering on the screwdriver/hacksaw blade trying to get it in further, but looking from the back, it doesn't go in any further. I've literally got hours in on this now, so I am desperately in need of help.
Yes. I find that a larger flat-blade screwdriver will work well for it as long as there is enough clearance in front of the fan. Twist it and pull at the fan hub to tilt it out, then handle the other side and it should then wiggle free.
Ive done this too many times this year so I’ve got it down pretty well.
Chris, thanks. That is kinda what I've been trying to do, altho I wasn't sure if the shaft on the screwdriver I was using was too thick. I guess a trip to harbor freight is in order. Should the tip of the screwdriver go to/past the red rectangle?
Probably doesn’t need to. I never had checked that part as I felt the screwdriver shaft be more of a slight wedge before twisting. When you have the driver twisted try pulling at the hub to tilt.
