'94 3.6T Instrument Display Issue
I am wondering if I can get help on this. The battery was flat for a while and now connected it to a slow charger and now starts fine. However, I noticed that after you turn the engine off a part of the display in the dial remains illuminated and will not go off. The display is the one which is showing the outside temp, turbo boost, etc. depending on what you select. Is there something broken or maybe as the battery was dead for a while a plug in of the diags tool with clear-down and reset of codes etc should clear the display?
I got the transistors of eBay but then decided not to screw with it and sent the OBC tach to Palo Alto Speedometer, Inc. http://www.paspeedo.com/
Palo Alto service was fast and I am very satisfied with the results - The charge was $185+UPS.
911Jetta (09-10-2019)
