If the original Bosch injectors flow 151.4g/min @ 3bar and you replace them with injectors that flow 138g/min, you will definitely run lean at WOT and you'll probably be on the very edge of (if not past it) where the O2 sensor can still correct the fuel ratio at partial throttle.
