Think I’ll rub the oil lines? See photos
Just got my Tramont RH replicas, 10"x18"ET50 in the rear and I’ve got about 4mm or so of clearance at the front end of the wheel. You can see in the photos a bit more clearance towards the middle. Car is lowered but may need a little more negative camber (will lose some clearance) but needs some toe out (will gain some more clearance).
Car is a 1990 so I don’t think it has the flattened oil line updated part number, though the line itself is oblong rather than completely round. Think I’m ok?
The line on my late '91 is partially flattened, but it also rests flush to the body. Yours has quite a gap. If you loosen the clamp on the short rubber hose near the tank, you should be able to get the line to sit against the body.
Depending on where/how you drive, a high-G left-hand corner could cause the tire to deflect enough to rub.
