warning light comes on randomly
Here are the details of my last three drives:
1) started fine, no lights, after 10 minutes master/pdas/buzzer on. reset master and pdas stays on until car is shut off.
2) (disconnected harness from PDAS/ABS unit and reconnected). Starts up with master/pdas(both)/abs lights on. They stay on until the engine is revved up to about 3500 rpm. Also, the little yellow LED on the console area that shows whether the 4 wheel drive in engaged is on until the engine is revved to 3500 rpm. While driving, the master warning light came on after about 10 minutes but no other lights/buzzer
3) Starts up with master/pdas(both)/abs lights on. They stay on until the engine is revved up to about 3500 rpm. Also, the little yellow LED on the console area that shows whether the 4 wheel drive in engaged is on until the engine is revved to 3500 rpm. while driving, the master warning light came on after about 5 minutes but no other lights/buzzer.
I will drive today and detail the sequence. Do you think that it is time to have this plugged into the "hammer" ?
thanks all,
Dave
thanks all,
Dave
