PS Pressure hose replacement
New hoses
Old hose. Lots of rags essential underneath.
Disconnected. Remove Banjo bolt and copper sealing rings.
Disconnect the pressure hose.
New copper seal washers
New pressure hose installed
13mm & 16mm hose for the flush. I used an irrigation joiner for the 13mm pipe.
The flush. Takes about 30 seconds with the engine running.
All back together. No leaks.
