Is Idle control valve – ICV supposed to move???
Hello,
Looking around for some information to clean the ICV I found this video on which apparently, the ICV is supposed to move. Is this correct?
Mine does not move.
Thanks,
Mine does not move.
Thanks,
This thread may help. https://rennlist.com/forums/964-foru...n-valve-3.html
The valve moves when you place voltage across the plug. You need 12v to get a good movement. Maybe better these days to buy the Aliexpress knock off for cents on the dollar.
Fwiw. I use electronics cleaner to clean them. The mechanism in there is an electro magnetic winding - and the fluid you spray in will get up in that area. So i switched since having taken one apart and gotten a good look at the internals.
