Best ride height and suspension options?
User
I should mention I've got 21mm spacers front and back.
My mechanic is recommending building a set up on https://www.elephantracing.com/ and purchasing through them. What is your guys opinion.... how necessary is it to replace each part when upgrading suspension?
I agree with others that best bang for the buck is to go with Bilstein HDs (or B6s now) and a set of H&R or Eibach springs. I chose KW V1s because Bilsteins had been on backorder for over 9 months, but perhaps they are now available. As Rob mentioned, KWs are a good setup but you definitely need the step down washers and it is a shame that KW chooses not to include them when they are aware of this issue.
I guarantee you they most likely move due to the weight of the car making them shift to one side or the other when going through turns. If like mine, you will find them both on the same side when you take the bolts out to put the step down washers.
It depends on the condition of the components, but don't let your mechanic unnecessarily pad the bill. You should determine if they are in need of replacement and you can do that with the help of your mechanic if you need advice, but ask questions and educate yourself. With that said, I recently went with coilovers and although the front end was tight, I decided to replace the front bushings at the same time since it was a "while in there" situation. I shopped around and settled on the following based on best pricing for each part: control arm bushings (RS hardness) and ball joints came from Rennline, rear top hats from Elephant, and front top hats/gaskets/outer tie rods/dust boots from local Porsche dealer.
Never realise the KW has that issue on front bush, I have mine for years.. Is it also the case for the V3 ?
I guess a good engineering place can machine 2 tube spacers for small amont of money
I check with my mechanics if they are 14 mm on the V 3 too
These are the washers Rob found online if you need some http://responsetype.com/shop/nissan/...-12mm-inserts/
KW Germany sent me 4 x #65350121 adapter sleeves for my V3s at no cost to me. KW Germany was aware of the oversight and said they should have been included with the V3s. I think this is a case of the engineering folks and shipping folks not talking.
I'm running KW V3s with BBI Uprights which is designed to plug with 993 components. Curious if 993 uprights require the step down washers as well. I tested my front hubs for play using my hands only and did not experience any play. Maybe I didn't apply enough force.
User
Well, with the reminder from this thread I took a few minutes to look at the front suspension and install the adapter bushings. One side was fine, no movement and the hushings just slipped right on. The other side had shifted slightly, 1/2mm, so I had to lean on it a bit to get the bushings installed. Glad it’s fixed now; one more thing off the list.
FWIW I did not use the spacer washers, I went with a plain bushing 12mm id, 14mm od by 6mm. Ordered from Amazon uxcell Sleeve (Plain) Bearings,... https://www.amazon.com/dp/B07JLZZNG5?ref=ppx_pop_mob_ap_share
These are slightly long, the actual depth is 5mm, however making the change is quick work with a file and they are otherwise a perfect fit and very cheap: ~$5 for 3
Anyone try the Ohlins DFV on the 964? I’ve heard good things about them on other platforms.
At the moment, I have HD’s with Eibachs, alignment and corner balance. The car is slightly higher than RS height. 215/255 tires on 17” wheels. Great for street and canyon runs IMO. Firm ride, but not punishing. Have done many 4-5 hour stints. Would recommend.
