can pulley noise/squeaking come from a belt... or is it the fan bearing?
I may be ignorant and I hope this doesn't sound to pedantic but has anyone tried a simple belt spray to see if it gets rid of the noise? If it does, source is found. Easy way to isolate the culprit.
Hey jeff - I've never heard of belt spray - is that a permanent fixer, or just a temporary deal??? Interesting... I might try water as mentioned by mojorizing...
Peter - I think you sealed the deal - -I'll just change out those damn belts and hopefully be done with the noise as you did!!
I'll keep ya' posted!
