Small Oil Leak Behind Passenger Rear Wheel
Cruisin'
I'm relatively new to the 964 world, just bought my C4 Cab this summer in July. I have a small oil leak coming from behind the passenger rear wheel that leaves a dime-ish size drop of oil on my garage floor when the car sits for more than a couple of days. It also leaks while driving because the right rear corner gets a layer of oily soot and dirtier than the rest of the car after driving a while.
What should I look at first when I get in there behind the wheel and quarter panel liner? The oil reservoir is there, but I'm wondering if the experts on here can let me know what may be the most likely culprit.
Thanks!
Duane
Thanks!
Duane
Cruisin'
Thanks for the replies everyone! I will certainly dig around and check that vent plug/oil filter drain plug is closed. Hopefully it is something this simple.
The line that runs from the oil filter housing inside the fender well, behind the engine to the driver's side of the block is prone to leakage. It's part hardline and part braided.
Agreed, I eventually traced back a few small drops as gravitating from the the engine feed pipe union on the filter housing. Any drops emanating from the the front of the secondary muffler (occasional smoking when warmed up) or muffler fixing bracket likely to be power steering fluid.
Cruisin'
I appreciate the help very much! Last night I started rooting around and found a tube behind the rear tire that has a rubber coupling with radiator type clamps on it. Both clamps tightened a turn-and-a-half. Fingers crossed it was something that easy!
