Is more caster always better
Hi Guys
Maybe Bill can chime in on this as well, I just replaced my struts with B6's with Eibach springs on my 1992 964 Turbo, I have the ride height set to RS spec's, The rear alignment came in perfect to RS spec's as did the right side front , caster set at 4.25 and there's room for more caster, but the drivers side cast wont go past 3.25 caster, if you turn the cam adjuster more it goes the opposite way. What could be the problem ? from what I can see, the control arms look the same and it's mounted the same. I confused. Please advise
Helio
Helio
https://rennlist.com/forums/964-foru...l#post11566180
My alignment guy maxed out caster on my 87 g body (since.sold). It hugely improved turn in, but it made the car noticeably less stable at high speeds-- say over 95 mph. I'd have to take grip the wheel and make constant correction to keep it tracking straight.
For the “is more better question”, gt4 runs 8.0-9.2. Think of it as dynamic camber.
Edit: Has anyone looked into using 993 top mounts? I believe those mounts are where the extra 993 caster comes from.
Increased caster does the opposite of this. High speed stability improves and steering response gets dulled. Think of a motorcycle with extended forks.
Black 3.2 your alignment guy probably added too much toe - I’m due for an alignment myself for the same thing. Carrying too much toe she likes to follow every line in the road like a puppy following scents.
^ Good call. Easy to add responsiveness with toe-out.
Re-reading, hope that didn’t come across as a dig on your knowledge Black. Just trying to avoid muddying the waters, which are already full of 3d geometry witchcraft
He did say he maxed out the caster, but I wonder if he maxed it out by reducing it all the way. If I remember correctly, he wanted to effectively shorten the wheelbase to make the car more tossable in the twisties, since that was my priority.
