Converting 964 Turbo Look to NB Control Arms
#31
I don't believe that is the case. The PET shows the C2/C4 and RSA all use the same rear hubs part number 964 331 065 06 Bearings are the same as well for all three.. They do differ from the turbo rear hubs which are part number 928 331 065 07. I have trailing arms from an RSA and a C4 both were identical as far as I could tell.
Mr. Wolfe
#33
I see what you are saying. The larger turbo rear trailing arms used on the Turbos & C4 widebody are different than the standard C4/C2. I was assuming you meant the NB C4. I do have spares but I don't want to part with them. IIRC the earlier rear hubs had a solid round centering ring hub vs the later which has a three part centering ring. If you can source the later it makes it easier for using smaller spacers.
#34
Mr. Wolfe
#35
Control arm conversion done. Wheels are finally mounted. Need an alignment, but the 12's do fit.
Will have better pictures when I have time. How can black wheels look so good in person and terrible in pictures?
Mr. Wolfe
Mr. Wolfe
#37
Well, I am not proud of the tires, but they will be swapped out. Before investing $1500 in good tires, I wanted to make certain my 12's would fit in the rear. I ultimately want to run 315's, but I decided to start with 305's. The big issue with that is, there is exactly ONE company that makes a street-legal 305/30/18 tire. Achilles. They are a cheap tire that actually gets good reviews from Mustang forums, but I can't imagine they are that great. I think they were less than $400 all in. Once I wail on the car and take some measurements, then I will buy the correct tires. Going with 12's, every mm counts so I wanted to get these sizes nailed down. Once thing I won't have is a car that rubs when I get on it.
Mr. Wolfe
TKO (08-31-2019)
#40
Mr. Wolfe
oMenRC51 (05-26-2020)
#43
Are you sure that will fit? I find I can push out the factory speedlines 11ET5 out by a few mm but I think 14mm outboard is right to the edge or more. Are you running a very stiff suspension or negative camber.
#44
Mr. Wolfe
