Losing power.......occasionally
Any suggestions on where to start looking?
http://philipraby.co.uk/porsche-data...ays-explained/
Just an fyi.
But for sure, all of us should have a dme relay in the glove box. If for no other reason than so when your buddy w a 964 who doesn't use rennlist can't start his car, at least YOU have one to get him going again...lol.
And check coils as was mentioned. Those are the first two places to look for intermittent power loss / engine cutoff.
Fwiw, the first time i lost a dme relay, the car would chug here and there on the highway. This went on intermittently for months prior to the dme relay failing. And at that time it hadn't occurred to me to check that relay. And then finally one random day in a parking lot, it drove to the store fine, and then just zero start when i came out. The starter just motored along, and the thing just wouldn't start. When i finally woke up to the fact that it was the dme relay, i pulled the new one out of the glove box and off i went feeling like an idiot for not having immediately thought of it.
I'd like that half hour of my life back...
Just an fyi.
My AFM was getting stuck occasionally and it felt similar to what you mention.
Just an fyi.
http://www.ftech9.com/new-products/?...tate+Relays%29
During the first drive with the new DME relay, the car started to feel jumpy during smooth throttle and the idle started to surge. Parked the car in the garage and it won't start.
So it's either a faulty DME fuel relay (even though I just installed a new one), an issue with the coils, plug wires or fuel pump. All over my head...
To respect OP thread, I will start a new one with more details. Please check it out (short video included).
Thanks for the input guys......i too figured it was most likely the DME relay. In my mind i had replaced the relay 'not so long ago', however when i checked my records it was 8 years ago! No problem i thought, just grab the spare out of the glove box.........it wasn't there.........then i remembered i had given it to friend a couple of years ago to help solve his 964 issues and he had replaced it with a new one. Obviously i had put it away in the garage in one of those boxes of "spare parts" (we all have them on the shelf in the garage right?), found it along with a fuel filter. So replaced them both as the old filter was 11 years old.
A spirited drive around local rural roads and all seems well.
