964 Forum 1989-1994
Fitting front 993 struts on a 964
Old Aug 26, 2018 | 07:10 PM
jskylarwilson's Avatar
jskylarwilson
Default Fitting front 993 struts on a 964
Hi all,
I've read that I can fit a 993 shock on a 964, and that the only major difference is the mounting holes on the bottom of the strut. The 993 uses a 12mm top and 14mm bottom, while the 964 uses a 12mm top and bottom.
I saw a forum on pelican where someone used spacers/bushings to fill the gap from the 14mm down to the 12mm hole. They said that the bushings came from rothsport, but rothsport doesn't have them.
I assume they're flanged bushings with a 14mm outside diameter and 12mm inside diameter. I just don't know how long (or short) they should be.
Does anyone have an idea where I could source these bushings?
Thanks in advance!
Skylar
Old Aug 27, 2018 | 08:14 AM
ffc's Avatar
ffc
In this http://forums.pelicanparts.com/porsc...uspension.html the thread owner sats Rothsport in the first post.
