Looking for a part which I don’t even know if it’s available.
Hello,
For the rear turn light, the “glass” by it’s selve is available (https://www.rosepassion.com/en/cat/porsche-964-1992-964-carrera-2-coupe-automatic-gearbox/M212/lighting/rear-indicator/B2663/rear-right-indicator-glass-964-rear-right/P247804)
Is it available for the center piece? If it’s is, where?
Thanks!!!
Thanks!!!
That’s the first time I have seen just the lense without the rest of the housing. The lense is glued to the housing so it may be a challenge to install a new lense and insure it is fully sealed.
Those lenses work fine. Heat the glue a little and careful taking the old lens off. They don't last as long as the new oem, but you save a bit doing it this way.
The center lens is not available on its own. So that one you are stuck buying new.
