Help me identify these wires...
Hi All,
When I had my A/C repaired, there was a pair of disconnected wires, brown (earth, I assume) and black (constant or switched power?), below the base of the windscreen. I think they are from the washer-jet. But then I can't find where they connect to...
![](http://www.classicshop.porsche.com/medien/pcos/pictures/zoom/9936280770101c.jpg)
I've recently been working on a stereo install, and I came across these wires again while investigating power cable routing options.
Anyway, here they are. Do any of you know where they plug in to?
![](https://photos.smugmug.com/964/Air-conditioning-repair/i-MXv7Gbs/0/93d15fc9/X4/brown%20wires%201-X4.jpg)
![](https://photos.smugmug.com/964/Air-conditioning-repair/i-6XG5cmB/0/7ca2203e/X4/brown%20wires%203-X4.jpg)
![](https://photos.smugmug.com/964/Air-conditioning-repair/i-Sr88XDC/0/9594185b/X3/brown%20wires%202-X3.jpg)
Thanks in advance...
![](https://cimg4.ibsrv.net/gimg/rennlist.com-vbulletin/380x676/9cf1a8da_24ef_49ea_8ae3_3ccc4b7bda39_f3b6702510cc3edc5f02be04112de46f353cd38a.jpeg)
The plugs look like this one should be close by
There are two small white plugs on either side of the car near the frunk hinges that they goto they are missing the female plug though it is available as I just bought a couple will have to look thru my receipts to find you the pn can do tonight. Your windshield washer nozzles have been replaced at someone point they are heated
![](https://cimg9.ibsrv.net/gimg/rennlist.com-vbulletin/1120x2000/951c97b3_d120_48f0_ac0f_6818b29f8f0b_82bbc3f9cfebf2bfb2cabf821df2fdd65997c39f.jpeg)
This is the plug it goes to
you can check a wiring diagram to verify this for sure on the right side of car there are 3 of those plugs
one for the frunk light one for the light on row cars that is on the fender and the one for heated washer nozzles
