Looks like a flatbed fun time
Pre or post doing the alternator belt repair? I should test to see what voltage we start getting the ABS light at so that others know directionally when a battery is approaching toast (I assume that's what you're looking for, right?)
That would be interesting to learn, but we might also see something about the health of your alternator. On my car, the ABS light will stay on at battery voltage but not at working alternator voltage.
My boys at Sonnen got me my parts expedited so project commences!
Tested battery after pulling off tender at 12.57 V.
Will get the other readings assuming I can finish the job
Ok can I ask a dumb question? Is the process of undoing the nut on the alternator shaft the most poorly designed thing ever?
I bought the the right tool even though a 10m 12-point would have worked just as well (as in not at all, at least in my case). Compound by the fact that there is nothing to brace or leverage either the shaft or the nut to get what should be a pretty darn secure nut.
the pelican instructions merely say "get the nut off." Fun part is I'm relatively confident that doing so, even with all the correct Porsche tools, either requires superhuman strength or some $200/hour magic.
Technical Guru
I tried everything I could with what I had (note not 2' pipes) but making a job basically impossible without special tools, then making it also highly difficult with special tools unless you are a slumlords enforcer, seems highly un-porsche-like.
Haha, you speak the truth!
After playing with it a couple more times (and trying to build a brace around the fan teeth), I may try and get an oil filter removal tool to help, and if that doesn't work, cry uncle and take it to my shop, tail between my legs. I do love working on my car myself, but at a certain point I'm throwing good money after bad, and maybe can get a discount from my shop if I donate the tool to them (assuming they don't already have it).
Ok quick question for the brain trust:
How far into the alternator hole should my idiotically short and utterly poorly designed tool supposed to go?
And then also do I need to be shiva to hold all these in place while trying to unbolt? Any recommendations from anyone to help (besides getting 2' pipes; or even if that is the solution, do I turn them counter clockwise to each other?
I also can't seem to simultaneously keep the tool pushed as far into the shaft as possible while also holding it still and turning the 24mm wrench (see shiva comment earlier).
Put the two handles close enough together to allow you to get one hand or both over both and squeeze together like lobster claw crackers. I'll take a pic tonight to help you visualise it.
Ok. This works for me, so I hope it works for you as well. Simply squeeze to undo. You might get extra purchase with an extender over the smaller lever but I find I have enough strength in my hands to do it as is.
Thanks John. I recently had my fan replaced which would have necessitated removing and retightening the bolt and it's really on there (plus I'm still flabbergasted at how poorly designed the whole system is...)
Its a sad day when I can't do the easiest of things on this car myself, and certainly not for lack of trying - the outer edge of the alternator shaft and my hands are both stripped pretty badly. FML.
BTW: I've never had a problem with the design at the rated torque level,
