ABS-Brake pas sensor wiring harness
I purchased from ebay spare wiring harness for front and rear because my current white barrel connector, where speed sensor and break pad sensor connects were all cracked and damaged.
The spare has 2 white barrel connector each. Picture enclose .
But this does not fit my late 964 C2, because on my car the existing wiring has only ONE connector barrel and on the other side the wiring runs all inside the car to the fuse box or abs controller i suppose.
My question is : can i cut the new harness, keeping only ONE barrel connector and some wire, and connect it with nice
soldering and insulation to the existing wiring which runs inside the car?
