I discovered a round electrical connector about an inch in dis near the opening in the dash for the stereo in my MY 91 C2 coupe. I’ve tried searching but no luck does anyone know what it is for. The wires from the harness to the connector are very short.
Here is a pic
Are you sayin it goes to the fog light switch? I guess I don’t ever recall seeing if they turn on or not certainly would be easy to check if the lights were in the car right now 😂
My stereo is out too think I will go out and check now will get back to you
Are you sayin it goes to the fog light switch? I guess I don’t ever recall seeing if they turn on or not certainly would be easy to check if the lights were in the car right now ��
Yes, I am almost certain it is the fog light connector that goes to the switch. Perhaps an unused connector for the rear fogs used on the ROW models. I have my stereo out so I can check tomorrow and confirm
My fog fog light switch is connected is the rear fog light switch located between the front fog light switch and the cigar lighter if so it is I think you are correct just for the rear fog light
Thank you very much I believe you got me pointed in the right direction😁👍
Originally Posted by LPMM
Yes, I am almost certain it is the fog light connector that goes to the switch. Perhaps an unused connector for the rear fogs used on the ROW models. I have my stereo out so I can check tomorrow and confirm.
I did a quick check on the wiring diagrams for MY91... Front fog switch has GR/BL, BR, GR, BL/WT wires. Rear fog switch has GR/BL, BR, WT/YE, WT/GN. That should help identify which one it is, hard to tell wire colors from your pic but my money is on rear fog.
It is is definitely the rear fog light switch I just went out and checked mine
Thank You very much another mystery solved
