How do we feel about these gear ratios?
The car is dual purpose both Street in track including the highway. Currently second gear feels too high and that's my main complaint. Basically this box will be very close to what I would do if I kept the five speed and reheated it but it's a 993tt box so all Porsche gears and triple syncros on 1st and 2nd with 6th of course for cruising. 6th would probably only be used on the highway. Also has factory lsd but I plan on switching that out for a GT unit.
1st gear: 3.82
2nd gear: 2.15
3rd gear: 1.56
4th gear: 1.21
5th gear: 0.97
6th gear: 0.75
Ring and pinion: 3.44
Pete
1st gear: 3.82
2nd gear: 2.15
3rd gear: 1.56
4th gear: 1.21
5th gear: 0.97
6th gear: 0.75
Pete
1st gear: 3.82
2nd gear: 2.15
3rd gear: 1.56
4th gear: 1.21
5th gear: 0.97
6th gear: 0.75
Pete
1st gear: 3.82
2nd gear: 2.15
3rd gear: 1.56
4th gear: 1.21
5th gear: 0.97
6th gear: 0.75
Pete
here is a comparison of a few w/ just the ratios
your's is the first one, I don't like it because of the big gap between 4 & 5, the g50/30 is the factory race transmission just about perfect, the g50/21 is the best street trans used in a 993
another way to see whats what is thrust or acceleration curves, here are the acceleration curves for an RSA w/ g50/03 vs the same car w/ your trans, I used this car because as we discussed you need the torque curve to start
same car but comparing the /03 to a /30
Thanks Bill- but are you sure you have the right data point on 5th? It’s 0.97 and should max at 151mph @ 6800rpm
Looking at this is giving me some pause on the unit I’m considering. I’m not finding many other options in the 6 speed flavor and it does pull the gears closer together than the g50/03. I’m also open to regearing a 5 speed as long as I can find a quiet gear for cruise speeds but likely I’d end up with 1-5 similar to the 6 speed I’m considering in the end anyway. So it may not be the best gearing for a 6 speed but it kinda looks like what I’d end up with in a 5 speed.
I lifted this from Steve Wong’s site as I plan on chiping so my car should be very similar. If anyone knows an online source for calculating thrust curves I’d love to put in this data. The blue is with his chip on a stock 964.
Pete
Pete
There are many ways to look at a transmission
Pete
Pete
here is the correct one, the acceleration curves are correct
here' the raw data w/ tires which have an effective 24.6" diameter based on rolling radius(265/35 x18)
Petespeed @6800 38 67 93 119 149 193
g50/21speed @6800 38 67 93 116 141 176
jebus...i was standing on my head. Sorry, i was reading it upside down .
Thanks everyone for your input. Bill’s charts were useful in my decision specifically looking at the first chart showing various boxes compared. The g50/30- seems fun but I’m guessing the engine that is was intended for has a peakier torque curve than my basically stock 964. At this point I’m thinking of changing just 6th cause I don’t think the 964 will pull such a tall gear all the way to 197mph- and I’m not sure I’d want to anyway without some splitters/spoilers not to mention more experience behind the wheel. A lower 6th would be still fine as an overdrive. This example- just for comparisons sake- g50/21 0.82 6th which looks just perfect. I want a quiet gear for this so I’ll have to see what the builder has access too.
Anyway the point of the thread was for me was to decide about the purchase and that I have done. Hopefully I’ll be able to work out the details with the seller in short order.
In that case the box will be sent off to Bill Rader whom I spoke with this morning- thx Matt!
Also a big thanks to Steve Weiner who has been a very helpful and reassuring with his guidance.
Fingers crossed........
Pete
Pete
for other comparisons obviously other options would be used
Pete
Pete
I thought I had posted this one, must have slipped up
Thanks Bill- do you happen to know the ratios on that 6 speed? Also would you explain the thrust units? If I understand correctly it’s feet per second- so for 3rd Gear the 6 speed is showing approx avg of say 1.25 ft/s2 over the 5 speed as it accelerats up to peak torque.
Pete
Pete
