Where to buy 60mm center caps for Speedline wheels
I recently purchased a 964 that had Speedline wheels on it and am looking to replace the black caps with silver ones with Porsche crest. Any idea where to get these? The 77mm ones are standard Porsche and Suncoast said they think it's aftermarket. Thanks.
Actually what black caps are you speaking of? The factory caps were metal and came with turbo script the factory optioned crested caps are NLA. They are similar to the 993 caps which have a different crest. The 993 versions have black lettering Porsche vs gold. The ones posted above will work but if your looking for the correct cap these are what you want but when found used usually run over $500 a set needing work.
I would use the 993's if it isn't that important. These can probably be found cheaper but this is what they look like.
I was looking for silver caps for my Speedlines – black isn't terrible, but I'd prefer the silver. The wheels above look like they have 77mm caps on them which wouldn't fit my wheels.
I didn't realize you had the Alessio's. The caps I posted fit the factory cup style speedline and cup wheels. I have never seen them with a Porsche crest for that wheel.
