Is this normal ??
Is this normal ??
After taking my C4 out last Thursday, having sat for two months, it turned over and stayed running the first time I triggered the ignition with the key (I was surprised). Well the weather is still nice here, so I decided to take it out again today. This time it took me 4 tries to keep it running (kept stalling). After that it wanted to stall every time I stopped, had a very erratic idle. Once the oil/engine warmed up, it was perfect. Is this normal ? Why would it not have done this on Thursday after sitting for two months ? Regards, Brady
Lead Rennlist
Technical Advisor
Lifetime Member
Lead Rennlist
Technical Advisor
Lifetime Member
Dear Brady,
You have to reset the DME when you leave the 964 for this long. The adaptive memory has become corrupted. The idle adaption is gone.
Ciao,
Adrian
964C4
Ciao,
Adrian
964C4
I had the battery disconnected prior to taking the car out (I was cleaning the front trunk and took everything out) I suppose disconnecting the battery would be the DME culprit. To reset the DME parameters, do I simply have to drive for at least 15 min. ? Regards, Brady
Lead Rennlist
Technical Advisor
Lifetime Member
Lead Rennlist
Technical Advisor
Lifetime Member
Dear Brady,
You let it idle for a couple of minutes and then yes go for a spirited drive and use as many rpms in as many gears as you can.
Ciao,
Adrian
964C4
Ciao,
Adrian
964C4
