Wheel Offset help please, 18"
Could someone please help me with the following, I have stumbled upon a set of Speedlines that I am now keen to fit, I appreciate that their may be a little work involved, however the wheels were a steal and I am not adverse to a project, nor am I in any kind of rush.
The wheels are 3 piece so I can split and rebuild to alternate sizes if required, however prior to a test fit can anyone advise if these would fit a narrow body C2 that has been lowered 30mm
Rear 10" x 18" ET56
Front 8" x 18" ET56
I would like to run, 225x40x18 at the front & 265x35x18 at the rear - However I am prepared to compromise should different sizes be more beneficial. - I am also prepared to roll the arches as per the RS and/or run spacers if required.
Any and all insight welcomed
Rear 10" x 18" ET56
Front 8" x 18" ET56
Rear 10" x 18" ET56
Front 8" x 18" ET56
Rear 10" x 18" ET56
Front 8" x 18" ET56
front should be 8ET50 to 52 so 8Et56 needs a 5mm spacer to get ET51
rear 10 should be ~ET45 so ET56 wants ~10mm spacer to get ET46
There is a little wiggle room but not much so spacers a little different will also work
