ABS Pump not working
I finally had time to test the ABS system by following the procedure in Adrian's book! The ABS pump (#96435575500 left front solenoid is not working (no ohm resistance across pins 1 & 2, while 3/4 and 4/5 have proper resistance).
I have read a number pf posts regarding rebuilding the pistons, but not about the solenoid.
Many posts refer to using parts from a Mercedes 190E unit #0265200043. now my question.....has anyone replaced the entire Porsche pump with the Mercedes unit?
That's for a C4, I have a C2, I don't know if it can be modified by just removing those parts.
