Front fenders seam sealer or not
When reinstalling the front fenders do most of you reapply the seam sealer. I am at the point I want to put the fenders back on and am at a crossroad. It is a lot easier to put everything back under the fenders while they are off ie oil cooler ac condenser and all the lines. Doing though will make getting the seam sealer on a real pain if not impossible. On the other hand putting everything back up under the fenders seems a real pain also.
I am leaning towards mounting fenders seal seams then reinstall everything else.
Do you mean the sealing straps that run by the frunk and door jamb? As far as I know that’s just butyl tape.
I am definitely going to put the tape stuff between the fenders and the tub . I was referring to the body sealant that covered the joint inside the fender wells the factory stuff looks to be off white a bit flexible and was covered by the factory paint
