For Rob Mugglestone Part II - Front Suspension
- one piece cast titanium uprights with carbon fiber cooling ducts
- ceramic ball wheel bearings
- titanium adjustable ball joints
- carbon fiber a arms
- titanium/aluminum drop links
- titanium/aluminum track rods
- integrated 300M ion impregnated axle/center screws
- titanium centerlock hubs with integrated titanium driving pegs
- 350 mm x 34 mm carbon ceramic brake disks with floating 2618 aluminum bells mounted with titanium bobbin systems with air gaps
- carbon fiber/titanium venturi-effect integrated left and right suspension links, cross-member and under-tray with access door
- titanium fasteners
to this will be attached:
- carbon fiber struts with integrated angle adjustment
- true 4-way adjustable titanium/aluminum dampers with blow off pistons --electron beam welded hard chromed titanium outer shafts and titanium hard chromed inner shafts -- connected by stainless steel braided Raychem covered hoses with machined fittings with –4 titanium quick disconnects to reservoirs with integral adjusters
- aluminum integrated front spring caps/spacer sleeves/nut sleeves
- beta c titanium main and helper springs with ultra high molecular weight plastic transition pieces
- aluminum 4-way spring rate adjusters with integrated titanium locking mechanism
- aluminum lithium monobloc 8 titanium piston calipers with air gaps, two pads per side, quick release pad pins, titanium quick disconnects in place of bleed screws and titanium quick disconnects in the lightweight stainless steel braided Raychem covered hoses with machined titanium fittings between the calipers and the chassis hard lines
- 4130 zinc passivate coated anti roll bar with 5-way adjustable 4130 machined ends with Orkot® bushings, titanium bushing stops, titanium mounting brackets and titanium fasteners
- titanium/steel center lock nuts
- one-piece forged magnesium center lock wheels with titanium pressure shims
un-freakin'-believable!
That is absolutely gorgeous. I would definately have to hang it on the wall over putting it on the car.
Robert, how much does the pictured assemblage weight?
Regards,
Jeff
Regards,
Jeff
Rob
re: Guru..er, I don' think so!!
If you read closely, it refers to the numvber of lamposts I've driven into!!
Jeff
IS assemblage really a word?? I think assembly might mean the same thing!!
Jeff
Must be American English....
From Dictionary.com
as·sem·blage n.
1.
a. The act of assembling.
b. The state of being assembled.
2. A collection of people or things; a gathering.
3. A collection of items from a single datable component of an archaeological site.
4. A fitting together of parts, as those in a machine.
5. A sculptural composition consisting of an arrangement of miscellaneous objects or found materials.
as·semblag·ist n.
I like #5 for Robert's work.
Jeff
as·sem·blage n.
1.
as·semblag·ist n.
Jeff
