DIY Drilled airbox
John, may be you don't love the sound under load at low rpm's, I agree in that, but the sound that comes out the "instrument" is soooo great from 3000rpm's an up!
May be you are getting too old for these things
Originally posted by John Boggiano
Sorry guys, it just sounds like a wet f##t to me!![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
How can you not be happy with your 964's glorious original soundtrack?
trying to sift through all that banter .....
Under 3000 rpm not the best but above that is where the fun begins?
John, nothing wrong with the original sound track just needs enhancing within certain tonal ranges (IMHO). And as you said, can always try it out with duct tape first !!
Lifetime Member
Lifetime Member
You get a very good idea of the sound if you download John M's lap of Castle Combe from Greg's site at www.carmovies.net.
Paul
C2 cab
Lifetime Member
Lifetime Member
Has anyone had a problem with a bad mass flow sensor that was caused by the oil that you have to spray a K & N filter with? That seemed to be the consensus on the failure of the unit. After two years, I'm taking out the K & N cone filer and switching back to the stock assembly, albeit, drilled out
Hey, I run straight exhaust...noise is all a matter of perspective.
