Build complete... with V8 (not for the purists)
Here is the build, a year after the CHP rear ended my car, we ended up putting a V8 in there and doing a lot of custom work to make the car perform at a very high level. 410 HP to the wheels, everything is solid now... enjoy the pics!
Attachment 1352860
Attachment 1352861
Attachment 1352862
Attachment 1352865
Attachment 1352866
Attachment 1352867
Attachment 1352869
Attachment 1352870
Attachment 1352871
Attachment 1352872
Attachment 1352873
Attachment 1352874
Attachment 1352875
Attachment 1352876
Attachment 1352877
Attachment 1352878
Attachment 1352879
Attachment 1352880
Attachment 1352881
Attachment 1352882
Attachment 1352883
Attachment 1352884
Attachment 1352885
Attachment 1352886
Attachment 1352860
Attachment 1352861
Attachment 1352862
Attachment 1352865
Attachment 1352866
Attachment 1352867
Attachment 1352869
Attachment 1352870
Attachment 1352871
Attachment 1352872
Attachment 1352873
Attachment 1352874
Attachment 1352875
Attachment 1352876
Attachment 1352877
Attachment 1352878
Attachment 1352879
Attachment 1352880
Attachment 1352881
Attachment 1352882
Attachment 1352883
Attachment 1352884
Attachment 1352885
Attachment 1352886
I don’t hate it!
what was the reasoning on the v8 bs origins? Was the original motor damaged?
Car was rear ended by CHP and so we used the opportunity to upgrade to more power... went with LS3 480.
https://rennlist.com/forums/964-foru...t-964-rwb.html
Very cool! How much modifications are needed to fit a V8 in there and is there any noticeable difference in handling characteristics or did you move things around in the car to change the weight distribution?
MEGA! Love the side window air scoops. More pictures of the systems in the trunk please.
Total weight?
I like it.
I like it.
Marine Blue- we used the Renegade Hybrids kits, it was supposed to be 100 hours of labor to get it all done but I bet we are more like double that, with all the little odds and ends that come up. The aluminum block LS3 is quite similar in weight to the stock motor and apparently just rides a little higher up - I haven't noticed any negative characteristics. The only issue right now is we are dealing with is where to dump the radiator air in the front, right now its under the car causing a little bit of lift.
BHMav8r - Don't know the weight yet but will collect once we corner balance.
Thanks all, will try to post some more pics soon.
Regarding the coolant air, the newer cars all vent into the wheel well from what I've seen but then you might be dealing with elevated brake temps unless you're able to add some type of a passive duct to move air into othe brakes when in motion. Newer cars use a plastic duct that sits on the suspension arm and directs air. http://forums.rennlist.com/upload/duct1.jpg
Wow. Must be a beast. The opposite of - All Show No Go.
Marine Blue, yes we do have ducts from the front bumper going into the brake backing plates for front brake cooling. In an ideal world we would cut a hole in the hood to vent the radiator air but I don't think it will look great... so playing around with fenders holes, under car holes in various sizes, etc.
Bloose - Correct its All Show All Go!
