Any link between Rear spoiler and Odometer...?
My Mechanic has just replaced my Rear Spoiler Module and I see that my Odometer is not working.This may have been like this for a while as I don't usually check my miles but it noticed last night. Speedo is fine, just the odometer.
The fact that your speedo is working suggests that the base signal source is present. That means the most likely fault is within the guage, which is most commonly stripped gear teeth. A quick search is your friend. Please note that if you DIY, you must use the face removal method. There is no other way that works.
