Frunk oil filter/tank/cooler
Has any one with a front oil tank or additional cooler added an additional or moved the oil filter to the front of the car. I am looking at adding a second oilcooler and was thinking of adding an additional oil filter. Not sure if this would restrict oil flow rate or not, so looking for answers. If you have added a second oil cooler what size lines and fittings did you use??? I converted stock oil lines and fittings to AN12, but most additional coolers I find are AN10.
While you wait for the pros to respond, check out this thread:
https://rennlist.com/forums/964-foru...te-design.html
Maybe some ideas from this 914 set up
Evanscott's 964 set up
911 J - thanks, all great info - have to figure out if the second oil filter would restrict oil flow or is it best just to keep 1 filter and move it to the front. Other concerns are the breather lines to tank if you move tank to front - what do you do with the crankcase breather lines. Thanks / have been track front frunk oil tank post -
