964 Buildsheet
964 Buildsheet
Hi Guys,
I am looking to get the build sheet for a 964 Speedster. I've already tried the rennlist VIN decorder but no cigar. Other VIN decoder websites show inconsistent information such as mileage and build year while others state "VIN was not found or is from an unsupported manufacturer"
VIN is WPOCB2963RS465304 with 6/93 build date. I don't have access to any vehicle docs at the moment.
Appreciate what you can find on this vehicle including listed options.
Thanks!
Thanks!
Weird, the VIN I pulled from the driver side door jam had a distinct O and looks different from the 0. Is this typical of Porsche VINs?
Well, it appears the VIN decoder doesn't list the options. More homework to do.
Thanks!
Well, I bit the bullet and ordered the build sheet from sun coast porsche.
I then translated the option code with the https://www.stuttcars.com code tool.
This is what we have:
Vehicle-Ident..-Number (VIN) WP0CB2963RS465304
Sales Type 964830
Model Year 1993
Block Flag
Blocking Date
Engine Type M64/02
engine number 62P51779
Gearbox Type A5003
transmission serial number 1010360
Tire Code PIRE
General information
Invoice Date 1 1993-07-09
Invoice Date 2 1993-06-16
Number of "Z" Orders 0
Country Equipment C02 USA
Trading Partner 4300010
Commission Number 060508
Body specifications
Exterior Paint Color A1V9
Interior specifications
Interior Trim VN
Interior Trim
Interior Equipment Code KL Leatherette
Seat Combination Number ATH
Seat Cushion Material LED Leather
Seat Side Support Material LE Leather
Seat Back Material LE Leather
Carpet Color Code 5FV
058 Bumpers with impact absorbers
130 Labelling in English
197 Higher amperage battery
218 License brakets front and rear
219 Differential
231 choice of tyres (bridgestone/conti/michelin or pirelli) (968)
249 Automatic transmission
288 Headlight washer
288 996: Light washers
323 without ESE-regulations (not a clue what this means)
323 Sticker, without ESE-Regulations
331 AM/FM Cassette w/2 door speakers
379 Series seat, left electrical vertical adjustment
380 Series seat, right electrical vertical adjustment
403 Pressure cast 17" wheels
423 Cassette container and coin box
434 instructions for export market
451 Prepared for radio for sport group
454 Automatic speed control
455 Wheel locks
464 Without compressor and tire pressure gauge
484 Symbols for controls
503 Cabrio variant (Speedster)
573 Air conditioner
576 Without rear fog light
602 Third brake light "High mount"
657 Power steering
659 Onboard computer
912 Vehicle without identification plate
Am I correct in stating the color code is platinum gray metallic?
Sales Type 964830
Model Year 1993
Block Flag
Blocking Date
Engine Type M64/02
Gearbox Type A5003
Tire Code PIRE
General information
Body specifications
Interior Trim VN
Interior Trim
219 Differential
455 Wheel locks
573 Air conditioner
657 Power steering
219 Differential open diff
249 Automatic transmission tiptronic
323 without ESE-regulations (not a clue what this means)not a 964 option code
323 Sticker, without ESE-Regulations not 964 option code
331 AM/FM Cassette w/2 door speakers CR-1 cassette
451 Prepared for radio for sport group reduced radio prep
455 Wheel locks
464 Without compressor and tire pressure gauge not a 964 option code
484 Symbols for controls US version
573 Air conditioner
657 Power steering
912 Vehicle without identification plate not a 964 option code
455 Wheel locks
573 Air conditioner
657 Power steering
Are you sure this is correct. I would check the option sticker under the hood or in the service manual to verify.
I used Porsche info to adjust what you have although Stuttgart is a great resource
I'm assuming this is the speedster tip that has been for sale?
Hi Cobalt,
The Speedster is a non-op vehicle in really poor condition both interior and exterior.
It unfortunately has a Strosek mega widebody body kit but with standard Porsche headlamps.
For a second thought it was a factory TL but build sheet says otherwise.
BTW, it has interior RS door cards but not listed in the buildsheet.
I'm going to check underneath the trunk lid to find out more.
Thanks for joining me in my journey to unlock the mystery.
PS. Which speedster were you referring to? The one on BaT?
If you pull back the trunk carpeting, the original paint code decal should be on the left side (towards the front, above the side "rail" below the headlight).
Example:
Also get a pic of the VIN/option decal under the hood if you can.
Example:
Hi John,
Since I am not the owner I did not want to fork over the $120+ cost for the COA.
I pulled the build sheet from Sun Coast Porsche in FL. Cost was only $10.
I am not sure where Sun Coast gets their info. I hypothesize they access the same Porsche network and that I would expect the Porsche COA build sheets to match.
Has anyone submitted their VINs to www.decodemyporsche.com? They advertise it as a free service.
Hi John,
then what is the techniches datenblatt...?
Hi John,
THANKS AGAIN!
