Any C4s with front differentiel leaks?
I have seen some seapage on the plastic cover, and I'm thinking I may have a slow leak on the front diff.
Has anyone experienced this?
Thanks,
G
Thanks,
G
Count me in. Came up on the OPC's PPI when I bought the car 18 months ago., but they didn't seem to think it was anything serious - it was slight seepage, as you describe. 2 services later, no mention and no trouble.
Would be interested in what you dig up, G.
Mine leaked too. Replaced the Seal & all OK now. Not an expensive job to fix. I'd have it done though. The last thing you want is the diff running without any oil in it!
IHI KING!
I had a small leak between the drive shaft and the housing. The repair was not expensive. I recommend getting it fixed. I suspect the replacement cost for one of our differentials is very high.
