964 Forum 1989-1994
VEMS Engine Timing
Old 08-24-2017, 03:45 PM
Raceboy
Raceboy's Avatar
You get misfire from plugs or leads and it fires to engine ground causing errors.
From your table, you have way too much advance at idle, twin plug engine wants just 1-2 degrees max.
And of course you can connect to VEMS while engine is off lol
Old 08-24-2017, 06:10 PM
Gus
Gus's Avatar
Raceboy - Ok here is a picture of my Timing trigger settings - TDC after Trigger is 84, First Trigger Tooth is 0. see picture of page -
What other settings within VEMS that effect the timing do I need to check and what should they be.
Am replacing spark plug wiring and plug connections - hoping to fix connection issues. Would this grounding issue effect the VEMS performance, engine control ??
Old 08-26-2017, 12:41 PM
Raceboy
Raceboy's Avatar
Trigger settings are correct. But please also check MAT retard table and CLT/MAP ignition adjust table for sane values.
I attached an ignition table that works nicely with 964.
Old 08-29-2017, 11:02 AM
Gus
Gus's Avatar
Raceboy - Checked my MST Retard and CLT/MAP tables - both are blank with no settings -
Can you recommend/send settings ?
Thanks Gus
Old 08-30-2017, 10:46 AM
Raceboy
Raceboy's Avatar
On CLT/MAP table I would suggest addressing higher cylinder head temps. Normal range on 964/993 should be around 100-120 C so start the temp row at 125 and fill until 155. MAP column should be filled with higher load units, starting from down to up start with 70 and until 100 (with NA) and with lower loads/temps retard -1 to -2 ad go higher. No need to retard more than 7-8 degrees.
Old 08-30-2017, 03:04 PM
jevvy964
jevvy964's Avatar
Enjoying all this - thanks for playing it out in public on RL!
Old 08-30-2017, 05:58 PM
neffets
neffets's Avatar
This didn't work for me, varioram here as well, i had to go back to more of a stock ign table to stop it from pinging at mid rpm, this is on 98 fuel.
My primary trigger settings are the same as Gus's
Old 09-03-2017, 06:15 AM
Raceboy
Raceboy's Avatar
You can limit the timing on the areas where it knocks and retain timing elsewere.
Quick Reply: VEMS Engine Timing
