964 Forum 1989-1994
Door pockets
Old Nov 27, 2003 | 02:02 PM
Flatsixer's Avatar
Flatsixer
Default Door pockets
Has anyone fitted any of the several aftermarket door pocket replacements on their 964 ? I eventually want to replace mine as the previous owner overtorqued the bolts on both sides and cracked the mounting forms inside the closeable lid ( or whatever it's called ). I noticed one company offers a real carbon fibre version now. The OEM replacements are about $1000 CDN each !!! I am curious to know what the quality is like and how they fit. I have also considered the RS America replacement panels as well, as I never seem to use the closeable pockets. That may be cheaper way to go. Has anyone installed these on their non RS America ? Regards, Brady
Old Nov 27, 2003 | 03:12 PM
garrett376's Avatar
garrett376
You can repair the cracked inside part using some sheet metal and some screws - make a sandwich of the cracked plastic portion with two pieces of metal, affix them together with sheet metal screws, and then screw that "sandwiched" part in to the door handle section - that can fix your cracked plastic part that makes the door pockets hang - and it will cost you about $5 in parts and maybe an hour to complete.
Old Nov 27, 2003 | 08:00 PM
Randall G.'s Avatar
Randall G.
Yep, Garrett's right. While my car was at Andial having the passenger side remote locking repaired, they fixed my inner pocket mounting area with a metal plate. At least I think it was Andial--didn't notice it before, and I know I didn't do it.
Old Nov 28, 2003 | 09:36 PM
garrett376's Avatar
garrett376
Here's how I did my doors, using plumber's tape instead of sheet metal (sheet metal would probably be stronger as I described, but this is all I had). You can see that the driver's side and passenger side broke differently, with the passenger side in a lot of broken pieces, thus the repair was different for each side...
Here's a closeup of the driver's side...
File Type: jpg
Old Nov 28, 2003 | 09:37 PM
garrett376's Avatar
garrett376
Here's the passenger side repair with the different layout:
File Type: jpg
garrett376's Avatar
garrett376
And here's the driver's side installed:
File Type: jpg
Old Nov 29, 2003 | 02:12 AM
Youcef's Avatar
Youcef
I discovered mine had been cracked by the removal process, there is a small regulator(I think) mounted to the door and if you try to remove the pocket it becomes hooked on this and cracks at the point you show here. I fixed my pocket and prevented the possibility of further cracks by removing a small segment of the plastic that get stuck when fitting and removing....sorry no pictures I have already put them back on.
Youcef
Old Nov 29, 2003 | 02:54 AM
Flatsixer's Avatar
Flatsixer
Thanks for the great info. I will try to repair myself. This seems to be a common problem. Regards, Brady
Old Nov 30, 2003 | 09:08 AM
Thomas Linser's Avatar
Thomas Linser
Flatsixer!
Oh yes this is a common problem!! My car has the same an two other cars I know had the same problem. I fixed it with a two compound Glue and fiberglass tape! No very pretty but strong!
Reagrsd Thomas
Old Nov 30, 2003 | 05:38 PM
Flatsixer's Avatar
Flatsixer
It's amazing, on such an expensive vehicle, we are dealing with petty things like this. Regards, Brady
