Porsche 964 ignition - where can I find info
Hey, my 964 has been standing for a while and recently it started cutting out and now won't start (it turns but won't fire). We've changed the dme and traced the issue and it seems that the ignition is not drawing from the coils. Not knowing much about Porsche engines we thought it might be the contact breaker (or equivalent) in the ignition. Opened it up but really have no clue. After researching on the web, I can't really find what some the parts are or how they function. (For instance, I can't find any reference to the part in the attached photo, except Hall sensor. I can't buy such a thing in the UK).
If anyone could recommend a manual that will explain how the ignition works and if someone could help clarify this part, that would be might helpful. Many thanks
RL Technical Advisor
The Hall sensor strictly provides camshaft reference for the knock sensors, not triggering in this application.
Ignition triggering is done with the flywheel's crank sensor and that's what replaces "points" in a Kettering ignition.
