Just got vacuum kit, a little help please?
Well I just got my vacuum tubing kit from Lindsey. It contains the tubing, 5 tee's, and this diagram:
Anyways, am I replacing all these lines? Just the black ones? Colored? Info would be appreciated.
TIA
TIA
If I remember correctly you can replace these with the kit from lindsey:
-left and right one from fuel vapor purge
-blow off valve to fuel dampener
-check valve to resevoir to vac supply
-AC to heater valve
-FPR
-throttle body
You can get three bigger hoses to replace and simplify the lines to idle stabilizer and brake booster from lindsey as well. I also replaced the line that goes to the center of the fuel vapor purge with one from the store. If you take the intake off it might be a good time to remove the CV and do the above mentioned simplifying around the idle stabilizer.
-AC to heater valve
-FPR
-throttle body
1 Post
You're replacing all the hard black lines with little black rubber elbows. Someone may have added some colored lines to your car at some point but for stock my first sentence is true.
John
John
